chracatoa
Sep 09, 2015Explorer
JD and Beastlet wrote:chracatoa wrote:
Also, dial your breaks correctly or every time you break on the highway you will feel a pull to the left or right.
If the trailer brakes are not working properly on one side I suspect it would pull to the other regardless of what hitch you're using.
Actually, try to dial down your brakes completely and brake at high speed - you will feel the trailer pulling you to one side. You have to make the trailer lead it. This also causes the "Hensley" bump.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
