NWRVGuy's avatar
NWRVGuy
Installing Winterization Valve
Hello everyone. I have a inline strainer/filter (SHURflow) on the intake side of my water compressor. Wanted to install a winterization valve and hose but there is zero room. Do I take the filter off ever year when I winterize? Any other creative solutions?
  • I don't even bother with the winterize kit on the pump. I just remove the suction line from the water tank and stick that in a bottle of pink stuff. I use about 3 gallons (washer/dryer).
  • I also have limited space, no room for permanent kit fitting. I just remove fitting on intake side of pump, and attach a pre-made hose with fitting in its place.
    Jerry
  • Use the forum search feature - plenty of posts where people use air to winterize their rigs.
  • Tough. Maybe a photo would inspire some ideas. Could the pump be moved to make more room? I'm thinking of my MH where a plastic tube with a couple of accessible elbows comes from the water tank to the pump. I could disconnect an elbow (threaded connectors) and hook up a hose to a jug of antifreeze.
    Some people drain the tank and pour a couple of gallons of the pink stuff in, then let the water pump suck it up and fill the lines.
Looking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Sep 04, 2018
