TundraTower
Apr 01, 2014Explorer
Interstate Bathroom....er....etiquette
Another naïve question from a newbie, but frankly something I've pondered even before we bought the TT.
So, you're cruising down the interstate and suddenly the traffic flow stops. A bad wreck, fire, police action, the President getting a haircut, whatever.
After sitting there a couple of hours, someone finally walks up and knocks on your door/window and asks if they can use the restroom in your RV. What's the proper way to handle that??????
If you let them, you know good and well they're going thru your stuff, and as soon as they get out the next 200 people behind you will be lined up to go as well.
If you tell them the tank is full or the facilities are broke, then you and your wife will have some explaining to do when you have similar needs, especially if in a trailer and your movement to same is obvious to the 200 folks behind you.
You could just tell them no. I paid the gazillion dollars for this rig and it's for my use only. (BTW, I'm ok with this approach)
We're headed down 2,000 miles of I-40 in 8 weeks and this is something I need to know. What's normal, reasonable, acceptable ??
