- wa8yxmExplorer IIII am not sure ferrite choke beads will work I'm trying to download the manual for the IC-2000 but my suspicion at this time is it is an MSW inverter. Will hold and update when manual finishes. If it finishes. Else I'll try a different path.
No it says it is a PURE SINE WAVE so if that is the case I do not know what the issue is. Go ahead and try the ferrite beads. May help.. Beyond that I'd need to see it with test gear.. and I don't have the specific test gear. - ByrogieExplorerThanks
- MrWizardModeratortry Ferrite snap on beads/chokes
on the battery cables to the inverter
one on each cable
purchase by wire size, inside diameter to snap close on wire and be snug
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 26, 2026
