time2roll
Jan 23, 2015Nomad
Do you ever have need for an inverter? A Victron Multiplus will add and combine power with the honda to get the air running and then recharge the battery. Temporary additional loads could be carried by the battery. This would allow the use of one honda and probably an extended run fuel tank. OK this is not exactly the easiest low cost solution but saves the cost of a second honda. Inverter can also be used alone if needed during quiet hours.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
