CA_Traveler
May 23, 2016Explorer III
Wow there is an incredible amount of issues here. First the Invisbrake does not charge the battery.
Next the charge line does not supply power to the Invisbrake it supplies power to the battery, from which the Invisbrake draws its power.
Invisibrake is a load or drain on the toad battery. A charge line is unrelated and it’s what charges the battery.
Most brakes including the Invisbrake draw very little power for the toad battery unless of course you are on the MH brakes a LOT. If there is a significant battery drain while towing with no charge line it is likely a toad related drain.
Roadmaster installed my Invisibrake and wired the charge line into the tail lights. I have to turn on the tail lights to get power to the charge line.You should be all over Roadmaster management for this – just unbelievable. Tail lights are not a charge line. A charge line starts at the MH battery and ends at the toad battery.
Looking for advice before your next adventure? Look no further.25,210 PostsLatest Activity: Aug 29, 2026
