CA_Traveler
May 23, 2016Explorer III
Yes the manual does say that but they show a 4 wire light connection from the MH to the Toad. Sure if you turn on the lights it MAY provide a small charge to the toad battery. And it's likely enough to support the Invisibrake.
But adequate charging for the normal towing drain of many cars/trucks is unlikely to happen with the lights on.
I view their statement as correct but perhaps misleading and more along the line of marketing speak.
I did upgrade from the 4 wire cable to the 6 wire cable which provides a heavier gauge charge line and an extra wire for the MH cab monitor light.
Looking for advice before your next adventure? Look no further.25,210 PostsLatest Activity: Aug 29, 2026
