CA_Traveler
May 23, 2016Explorer III
If I recall the manual says up to 2A charging. With the typical long runs to the MH rear lights and small wiring for the lights that is not intended to charge a battery plus the additional wire to the toad just how much charging would you get?
Some cars don't have any drain when towed. But others in the Aux ignition switch position have various draws some of which pulling a fuse is recommended. Adequate Invsibrake charging for some cars and not others.
Looking for advice before your next adventure? Look no further.25,210 PostsLatest Activity: Aug 29, 2026
