superrayzor's avatar
superrayzor
Invisibrake not charging tow vehicle.
Dealer installed an Invisibrake. I am towing a 2007 Honda Odyssey following the procedure outlined on this forum. I make sure EVERYTHING is turned off before I tow it.
I repeat the procedure and let the engine run about every 2-3 hours. At the end of the day I have a little trouble getting the engine to turn over. So far haven't had it die completely, but it's getting close.
I have the 2016 F53 chassis. Is there something special I need to be doing to get the tow vehicle battery to charge with the Invisibrake? There is a red wire running to the battery on the Odyssey which I assume is meant to charge it.
  • With the tail lights on that level of current flow might be enough to drop the voltage enough to prevent adequately charging the battery.
    LED tail light bulbs..?
    300W DC-AC converter(***) with an inexpensive battery charger.
    *** works down to 10.5 volts..
  • Roadmaster installed my Invisibrake and wired the charge line into the tail lights. I have to turn on the tail lights to get power to the charge line.
  • Bobbo's avatar
    Bobbo
    Explorer III
    Are you absolutely sure the 12v charge wire from the MH is carrying power to the Invisibrake? It has to get its power from somewhere.
