GWolfe
Mar 22, 2020Explorer
Cummins12V98 wrote:
When the tire is FLAT and the wheel is on the ground what are you going to have with you to fix it?
This is my way that i don't have to even touch the ground. What would you do to get under and lift the axle with a 13 or 14" wheel?
On both of the single axle TTs and one pop up I had, with 10" wheels/tires, I was able to use the bottle jack that came in my truck to lift the trailers. The jack even has the long handles so I can slide it under the trailer without having to get down on the ground.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
