Ro646a's avatar
Ro646a
Explorer II
Aug 03, 2015
Is anyone towing a Chrysler minivan?
I just bought a really nice 2008 Town and Country Limited. I know that the owner's manual says that it is not towable 4 down, but Remco offers a lube pump and other items needed for towing that vehicle.
Does anyone have any experience towing one of these with a transmission lube pump installed? Any advice would be greatly appreciated.
Thanks
  • Thank you busyguy for your input.
    I wonder if anyone has put a lube pump on a later model T&C with the 6 speed transmission. I read somewhere that there might be problems using the Remco pump on the 2008 and newer models with the 6 speed trans.
  • Hi
    I towed a 1997 Chrysler T&C for about 40,000 miles using the remco pump. When I sold the van I bought a 2004 PT Cruiser and took the pump off the van and installed it on the Cruiser. Which I am still towing. The original pump lasted a few more years and then started leaking. Bought a new one and no more problems. The only problem I had with the pump was finding a place to mount it in the engine compartment. Finally took the inside wheel well cover off the left front and mounted it there. Remco sells a bracket for the Cruiser but I don't know about the van.
    I did all the work myself and its not hard. Just follow the directions and you will be fine. The van towed fine.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
