AH64ID
Jan 12, 2015Explorer
Lots opinions on this... What are the specs on your rig?
There usually isn't a lot of room between axles and GVWR on 1/2 tons...
My 0.02, I'd be more nervous about exceeding GVWR on a 1/2 ton than a 3/4 or 1 ton SRW truck.
Brakes are sized off of GVWR, so that's a concern. The axle brakes on the 1/2 ton are at their design limit and placard limit if fully loaded.
The suspension will be fine, if you are under axle ratings.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
