SlowBro
Jan 18, 2015Explorer III
Yeah, I'm probably going to be just fine. From earlier in the thread:
My biggest concern. But it doesn't look like I have much of a choice, so I guess I'm not going to worry about it.
I have no warranty.
Such a citation (likely) wouldn't occur if I'm right at or under the GVWR. Of course I can be sued but that's not likely to be upheld if I'm at/under.
Same as above.
Ok good.
kaydeejay wrote:
GVWR is the MAXIMUM weight at which the manufacturer will stand behind the vehicle in meeting those regs.
If you go over GVWR your truck is NOT going to fall apart but be aware of the following possible (but unlikely) scenarios:
* You may wear out driveline components faster than their designed life
kaydeejay wrote:
* Your dealer could void your drivetrain & suspension warranty
I have no warranty.
kaydeejay wrote:
* If you were involved in an accident you could be cited for overloading
kaydeejay wrote:
* Following such an accident you insurance company could terminate coverage
Same as above.
kaydeejay wrote:
Bearing all of the above in mind, I would not get too excited about 200-400# overweight.
Ok good.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
