blt2ski
Jan 18, 2015Moderator
cdevidal wrote:rhagfo wrote:
Sorry, just having a little fun with the preciseness of your calculations. :B
No harm, no foul ;)rhagfo wrote:
Towing at or slightly over GVWR and/or GCVWR, you want to be sure all braking systems are in good working order.
Under. At or slightly under. I thought I'd read earlier in the thread that being right at the limit could be a problem, but when I re-read it (see the next post I wrote above yours) I see there's no real concern.
One thing to remember about GCWR, it is generally a go power rating. So if you pull the same trailer with a smaller motor, than the larger one that is rated higher, the chassis will handle the trailer assuming everything is loaded to spec. BUT< speed up a grade will be slower than with the larger motor.
On the other hand, as happened to me back in the day. I went up a hill at 12K with a C2500 at 12K gcwr, GCWR was 8500, gvwr is 8600, Grade was around 20%. Meanwhile the almight 4bbl 454 in my C3500 dumptruck with the almighty Turbo 400, not to mention a dually! sat at the bottom of the same driveway, blowing up its tranny. Dispite a 16K gcwr, and it was combo'd at 12K also!
At the end of the day, just because you are under a manufacture rating etc, does not mean it will always work for your application. I never once felt white knuckles in my 96 CC at 16 to even 20K gcw. Dispite the 12500 gcwr GM gave it. In fact, it usually out did, never stalled out on a grade compared to either the 88 or 89 454's I had with 16K gcwr's. They stalled out on any grade over 15-20%.
Just because it is rated to a given number, does not mean it will do what YOUR specs are. The specs are based on an engineer that is not using the rig as you might might. Because of my experiences with light duty truck gcwr's, I do not follow, nor believe them to be true ratings, at least as to HOW I use the trucks. A few I can believe, others, not worth their wt in gold!
marty
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
