DrewE
Nov 11, 2017Explorer III
There's no need for the gasket material to be kept moist with water. If you think about it, the seals on the output side of the valve (which are the same material as on the input side) are dry practically all the time, or at least should be. The whole point of the gasket, be it rubber or silicone or whatever material they use, is to be impervious to water as it seals.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 12, 2026
