- wa8yxmExplorer IIIIn some areas keeping the FRESH tank full is recommended.. Change the water from time to time and use a bit of heat if needed.
WHY: Well can you count on your default water supply? - Dennis12ExplorerCall and get a price to repair what may or could go wrong. Then you make up your own mind from that point.
- Deb_and_Ed_MExplorer II
ScottG wrote:
Keep in mind that if you leave enough water in the tank to fill the shot section of pipe going to the drain, it will freeze and bust the pipe.
Agreed!!! The ability of ice to destroy things is amazing. And it forms rather fast with temps in the 20s.... - Deb_and_Ed_MExplorer II
But chances are that the fresh tank still has a skinny little drain tube that extends underneath the RV, that will freeze in the blink of an eye.... - rv2goExplorer II
The OP stated that the RV would be in storage.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
