- rv2goExplorer IIWhen I gamble in Vegas, I lose. :B
Why gamble on the weather, drain the tanks and winterize. - gboppExplorerYou're storing your rig in Las Vegas. Gambling with the weather is your choice.
Personally, I would drain the tanks and use RV Antifreeze as recommended above.
Then you know the tanks won't freeze in the event of colder than normal weather. - ScottGNomadWater wont keep the seals pliable. They will be fine without anything in the tank.
- turbojimmyExplorer1/2 full probably won't hurt anything, but also unnecessary. The seals you're concerned about are at the very bottom of the tanks. I just pour enough antifreeze into the tanks to know some got down to the drain valves. I dump some in the toilet to keep that seal wet, and a bit into the drains.
- 352ExplorerIt is only as crazy as you think it is.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
