pianotuna wrote:
Hi,
It is almost certainly too small to operate the air conditioner if you intend to run the generator on propane. Output may be reduced by one fifth, so it is now a 2000 (surge) VA generator, not a 2500 (surge) VA unit.
Be aware that output also drops with altitude, so what will work at sea level, won't in the mountains.
This is a good point.
You may be able to set up a crude propane feed before you invest in converting it. It's obviously not the safe way to run any propane system but it can be done for testing.
I just started my 13,500. It's 72 degrees out and it pulled 13 amps at start and settled into a 6 amp draw. Still doesn't give us a starting head pressure figure.
