Bobbo
Jun 17, 2013Explorer III
Just Lee wrote:
Right now when hooked up the TOAD uses the Brake/Running Lights for everything Running/Brake/Signal........ However my TOAD lights work whether the key is on or not. So I disconnect the Battery because I do not want the lights to be fed from 2 sources.
Mine is wired exactly the same way, but I don't have a problem with it. The only downside I see is if the MH turn signal is on and the toad's brakes come on, the toad's turn signal doesn't flash. The constant brake light signal from the toad's brakes keeps it on. However, that happens whether the dash light is hooked to the RB or the toad. It is just the way those work.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 16, 2026
