Bedlam
Mar 04, 2014Moderator
Buck50HD wrote:
Also, the F250 with camper package definitely appears to be the ticket if you get a 250. It sits high, with a 2" rake like a 350 and has the same springs and includes a rear sway bar. It's a $160 option and is much better value than paying the extra $900 for the 350 base price. Combine the camper package with the 18" A/T or 20's and you have the same hardware as a 350. I have a hard time paying $900 for an F350 door sticker.
One thing that I really don't like about the base F250's is that they sit perfectly level. Hook up the 5th and you are sure to look funny with the rear sagging. Doesn't make much sense to me on a HD truck. My F150HD bed rails are 57.5" high. F250 are 54.5-55" high and the F350 are around 57.5-58. Don't even need a tailgate step with the 250:) A gas GM 2500HD was around 57".
The F350 still uses a 2" taller block under the rear axle than the F250. I could have thrown that taller block under mine with longer u-bolts, but went with StableLoads and Firestone air bags to level my back end out. I was running the 18" wheels with 3590 lb rated rims until I went to the 19.5's with 4500 lb rims.
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Dec 18, 2013
