kfp673's avatar
kfp673
Explorer II
Sep 08, 2021
Is there a quiet water pump?
We have been increasing the amount of boondock camping we are doing so I started carrying a 35 gallon water tank in the truck. Currently using a drill pump with intentions to buy a 12V transfer pump some time soon. But that got me thinking... The water pump in our trailer is the typical loud rattling pump. Not a big deal during the da, but a toilet flush in the middle of the night will wake me up (pump is in a compartment in main bedroom). I figured there must be a "high end" and obviously more expensive pump I could install in the camper and then repurpose the existing pump to become my transfer / backup. Is there such an animal? I'm happy to pay a premium for something smooth and relatively quiet. Any suggestions?
Thanks!
  • opnspaces wrote:
    I'm not sure if there is a quiet pump. But as above there are a couple of ways to make it quieter.
    Make sure the pump is mounted on a rubber or soft foam pad.
    Cut the PEX tubing near the pump and add some hose clamps and flexible line.
    Use some foam and follow the water lines out of the pump. Wedge a piece of foam between the hard lines and the walls and floor.
    Add an accumulator tank into the system. An accumulator will allow a flush or two without turning on the pump making for a silent flush. The downside is once the accumulator pressure bleeds off the pump has to run longer to re-pressurize the system.
    Exactly. Except you don't need to cut the tubing. You can buy flexible hose with the fittings at pretty much any hardware store. Your goal is to isolate the vibrating parts from the stationary parts, and use an accumulator to reduce how often the pump runs.
  • JimK-NY wrote:
    valhalla360 wrote:
    If it's the middle of the night and I hear the pump cycling, I know there is a problem that needs to be sorted out. .....
    When the temperature in the hot water tank drops, the pump will run to built up pressure. I turn both off at night.
    Never had an issue with it.
    Probably because we both get up and use the facilities during the night so that resets the pressure.
  • Awesome feedback everyone. After reading these replies about insulating the pipes and mounting on something rubber I googled it and found a bunch of videos saying the same thing. Never considered that. Figured the pump itself was just noisy, but insulation and rubber pad is a cheap and easy thing to try. I'll give that a shot first. Thanks all!
  • The pump is not very noisy as made, but (as mentioned by others) the installation and the hard lines inside an RV amplify the minor pump sound!! Example: I am using one (same model as inside our trailer) to pump from a 200 gal tank to the trailer up on our property in NE WA. It is "plumbed" with 3/4" hose from tank and then to trailer. You can stand right next to it and all you hear is a hum from pump!! The trailer pump and lines have been modified and insulated from contact with cabinets and floor, and it is still not near as quiet as the outside pump!!! Better than when delivered, but the basic "rattle" is still there, but reduced to a more acceptable level!!!
  • Just for snots and grins, put your cell phone on vibrate, and lay it on a table. Grab your wife's phone, dial your number.
  • ksbowman wrote:
    I had a noisy pump in a 5th wheel I had. The pump mounted to the floor so I added a rubber pad under it and I added an accumulator tank. It really quieted things down and at night the stool could be flushed several times without the pump coming on.
    Having three truck campers and later three 5th wheel rv trailers some pumps were very noisy depending on where and how they were mounted.
    I had all types of rubber pads available at work that all had different durometers. From the trash bin I chose a 1/2" thick soft 40 durometer the size of the pumps mounting surface. This cut pump noise 300 percent to super quiet.
    The accumulator water tank eliminated constant pump cycling.
    Some of the pumps were mounted on a wall and weren't as noisy. My noisy ones were mounted on the plywood flooring.
