Skibane
May 15, 2022Explorer II
spoon059 wrote:
The only possibly downfall that I am currently seeing is the inability to cool multiple rooms. My camper has a rear bunkhouse and a front master bedroom. With the doors closed for privacy/light, it would prevent the even flow of conditioned air. Putting a cassette in those areas would take a LOT of space and would be overwhelming cooling/heating power in such a small area.
There are ducted mini-splits available - Could be mounted in an overhead cabinet, with the ducting routed along the back side of adjacent cabinets.
Some of the ceiling cassettes also have knock-outs for running small ducts to other areas.
StirCrazy wrote:
and pretty power hungry, 105Amps at 12V on max.
That's "only" 1260 watts - Not much different from a typical 120V unit.
One problem with 12V units is that the high amperage requires thick wire, and introduces electrical losses. If you have a long wire wire run between the unit and your batteries, you might actually get less loss by using an inverter with a 120 volt model instead - even taking into account the conversion losses inside the inverter.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
