JRscooby
May 15, 2022Explorer II
Skibane wrote:
If you have a long wire wire run between the unit and your batteries, you might actually get less loss by using an inverter with a 120 volt model instead - even taking into account the conversion losses inside the inverter.
I would assume "split" would mean you could mount the compressor, the big load, near the battery
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
