StirCrazy
May 16, 2022Moderator
Skibane wrote:spoon059 wrote:
The only possibly downfall that I am currently seeing is the inability to cool multiple rooms. My camper has a rear bunkhouse and a front master bedroom. With the doors closed for privacy/light, it would prevent the even flow of conditioned air. Putting a cassette in those areas would take a LOT of space and would be overwhelming cooling/heating power in such a small area.
There are ducted mini-splits available - Could be mounted in an overhead cabinet, with the ducting routed along the back side of adjacent cabinets.
Some of the ceiling cassettes also have knock-outs for running small ducts to other areas.StirCrazy wrote:
and pretty power hungry, 105Amps at 12V on max.
That's "only" 1260 watts - Not much different from a typical 120V unit.
One problem with 12V units is that the high amperage requires thick wire, and introduces electrical losses. If you have a long wire wire run between the unit and your batteries, you might actually get less loss by using an inverter with a 120 volt model instead - even taking into account the conversion losses inside the inverter.
thats what I was talking about bigger wiring huge battery bank and so on. they are made for big rigs that are ideling all the time now to run off an adverage rv when boon docking. if you use a 120V model now you have inverter inefficencies to worry about also which is even a larger draw.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
