JRscooby
May 16, 2022Explorer II
Peter_Crowl wrote:
Semi tractors with Split system air?
Just google it.
here, for example is a link to a you tube video on the installation.
https://youtu.be/GUQAj7dTsSo
Not sure where the link takes you. I see some yeahwho cobbling some snot together in his yard.
I know my experience is a decade out of date, but when I retired 3 major options;
A)Sleep where idle restrictions did not apply/where not enforced, idle engine.(My choice)
B)Add a Auxiliary Power Unit, which is a small diesel engine that powers a second AC compressor and a second alternator. I think all also have inverter to power high voltage loads. (If had not retired, my old Pete would have got this upgrade)
C)New trucks could be optioned with a AC unit that was advertised to maintain cab temp for 10 hours on power stored while working the truck.
Now I'm not at all opposed to DIY, but if, like you say, he has to idle his engine to run the AC, what has he gained?
To talk about the RV world; I often read "solar will take care of all power needs, unless I need AC. IMHO, a ICE powering the AC compressor directly instead of a genset might make more sense.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
