StirCrazy
May 18, 2022Moderator
JRscooby wrote:Peter_Crowl wrote:
Semi tractors with Split system air?
Just google it.
here, for example is a link to a you tube video on the installation.
https://youtu.be/GUQAj7dTsSo
Not sure where the link takes you. I see some yeahwho cobbling some snot together in his yard.
I know my experience is a decade out of date, but when I retired 3 major options;
A)Sleep where idle restrictions did not apply/where not enforced, idle engine.(My choice)
B)Add a Auxiliary Power Unit, which is a small diesel engine that powers a second AC compressor and a second alternator. I think all also have inverter to power high voltage loads. (If had not retired, my old Pete would have got this upgrade)
C)New trucks could be optioned with a AC unit that was advertised to maintain cab temp for 10 hours on power stored while working the truck.
Now I'm not at all opposed to DIY, but if, like you say, he has to idle his engine to run the AC, what has he gained?
To talk about the RV world; I often read "solar will take care of all power needs, unless I need AC. IMHO, a ICE powering the AC compressor directly instead of a genset might make more sense.
Idle engins, APU (still a engin running and so on. I have a few friends who retired from the military and are trucking.. the lack of maintenance or cheepness of the companies boil down to the apu's are not installed or seldom work. when I pick them up for visits as they are passing through almost every truck at the truck stop is still running. I am aware there are other means aside from running the truck but they are seldome used.
could we do it in an rv? hell ya but people whine about the cost of a second battery, how about that 5th or 6th I was looking into this option a few years ago but decided against it as I would have to tow a trailer around with fold out solar and a huge battery bank as I would need to run it 24/7 if I camped around home in the summer.. the most efficient one I found was about 78amps at half speed. and full speed was comparable to what we already have when you convert the wattage, just 12V is easier to tie into a system.
what I decided to do instead is camp elsewhere out of this desart I call home and go to higher elavations, west coast or a different provence, and camp with the camper more in the spring and fall. the 5th wheel if we need to stay around this area we just get a place where we can plug in so the dog has AC if he isnt with us and we can sleep at night.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
