way2roll's avatar
way2roll
Trailblazer
Feb 22, 2023
Is there such a thing a decent valve extender?
In every MH we've owned the valve extenders leaked. This brand new MH is no exception. Prepping for a trip and checking PSI and sure enough one of the rear duals was only showing 20 PSI. Turns out the extender was the culprit. And not at the threads but at the crimped joint. So I removed it and will make due on this trip but I need to get new extension because I simply can't check PSI or fill the tires without them. Darned if you do and darned if you don't. So, is there such a thing as a good set of valve extenders - and on top of that, ones that work well with an aftermarket TPMS - preferably a flow through?
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 08, 2026
