cougar28's avatar
cougar28
It could have went bad!
What's the single worst thing that you did or didn't do that could have really went bad but didn't?
Couple years ago first trip of the year. One of those spur of the moment trip-got in a hurry because getting off work late. Get home the DW already loaded most of the stuff. I jumped on the tractor and use the bucket to load and install the 5th wheel hitch. Get that done hook the rv up -do a walk around all is good and hit the road to the camp ground.
Get there all is good for the weekend- pack up head home. Get home park the rv in the carport-unhook and notice on a little table I have there my 4 hitch bed rail pins! Yep pull the rv 40 mile round trip with the hitch not pined to the bed rails.
  • We were about 5 miles from our destination when the TPMS alarm sounded. Rapid pressure lose. Right rear tire flat. No big deal, had room to pull over to put on spare.
    Pulled tire off and noticed a deep groove around the rear sidewall of tire. It’s then I discovered the problem. The shackles holding the rear axle leaf springs to the center equalizer had broken. The tire had been rubbing up against the shock absorber bracket.
    Since we were so close I put the spare on and we limped the final few miles. It was then I discovered that the shackles on the other side was broken also. So basically the only thing holding the rear axle on was the two rear leaf spring bolts. Can’t say how long it had been this way. Shudder to think what could have happened.
  • I'm almost too embarrassed to share this. My FW was brand new and I was in the storage yard trying to back into a narrow space and had the FW in a tight angle to the truck. I apparently had my brake cable hooked up with not enough slack for the tight turn and it unplugged from the trailer. The rig came to an abrupt stop. I quickly jumped out of the truck to see what happened and saw the cable was disconnected. I climbed into the bed and plugged it back in. What I didn't realize was that I didn't put the truck in park when I jumped out - it was still in gear! Next thing I know is the rig is driving itself across the lot with me in the bed. I about broke my neck jumping out the bed and scrambled to the open door to slam on the brakes before it hit a building. OMG was I lucky! I could have hurt myself or got tangled up under the rear wheels of the truck when I flopped out of the bed to the ground. I beat myself up pretty good for being so careless and stupid. The RV god was watching out for me that day. Looking back I should have just unplugged the brake cable and it would have stopped the rig but I was panicked at the time and didn't think of it.
  • Years ago, When I had my first Travel Trailer it had a single axle. The door was toward the front. I unhooked it at the campground walked inside and toward the back. When I did the jack on the front of the trailer came off of the ground and the trailer started to roll down the hill toward the lake !!! I ran toward the door on the front of the trailer and the jack came back down digging into the dirt.
    After I got it reset on the camping spot I drove to town and bought some wheel chocks.
    It's funny now but, at the time it was scary and embarrassing.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
Related Content
