- dodge_guyExplorer II
ChooChooMan74 wrote:
Sometimes I can't post through rv.net and go through the trailer life portal.
I've had the same issue. I now use the trailer life portal. - BB_TXNomadI typically use the trailer life portal. And the url does show forums.trailerlife.com. But it is still the same rv.net open roads forum.
- ChooChooMan74ExplorerSometimes I can't post through rv.net and go through the trailer life portal.
- FunnyCamperExplorer III have no troubles, I have it bookmarked in favorites, just click and here.
- RoyBExplorer IIRoyB
I use the WOODALLs portal here most of the time and it says WOODALLs across the top banner but it is still the RV.net forum content... My other portal I use is TRAILERLIFE Portal. I think it has the RV.NET LOGO for main banner... Just switched to TRAILERLIFE and it does have the RV.NET banner...
I vacated using the RV.net forum portal a long time back. Always had issues for me... About the only time I go to the RV NET main forum page is to check out if it is up or not - especially when either WOODALLs or TRAILERLIFE portals go down... Usually is down as well at that time.
The two portals I use has the same LOGIN info and same RV NET content...
RoyB
King George VA - gboppExplorerThere are several portals to get on the forum. I normally use rv.net but, sometimes it doesn't work and I use another one for a day or so.
I don't know what causes the problem.
Looking for advice before your next adventure? Look no further.25,103 PostsLatest Activity: Jan 21, 2025
