ferndaleflyer's avatar
ferndaleflyer
Explorer III
Jul 23, 2023
It wouldn't go anymore
Take off for Darlington, SC with race car in tow. Tach stops working, oh well, I keep going. Notice volt gauge isn't working right, keep going. About 1/2 way there I pull up to a stop light in the left turn lane the light turns green and my DP don't move. Motor is running, generator is running, we aren't moving. After awhile I figured that the alternator had stopped and the battery that supplied the juice for the transmission was dead. Now What? Middle of no where. I ran an extension cord from the nearest compartment, Generator is running, connected my maintainer up. Then I hooked a set of jumper cables from the house batteries to the chassis batteries. Viola, everything works so I get it out of the road. Taped the extension cord to the side of the bus, bunggy cord the battery compartment as near shut as I could and headed up the road. I mean Jed Clampet had nothing on me. So today I find 2 bad batteries and it goes in the morning for a alternator. Life in an RV
  • JaxDad's avatar
    JaxDad
    Explorer III
    One of my fathers favourite lines, usually directed towards my mother, was “It worked didn’t it?”
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    I would have just jumpered house to chassis.. and in fact did that on my Gasser.. But I now that path might not be that easy on a DP due to placement of the batteries (mine were close enough to get by with a single jumper all "Under" the RV)
  • Never underestimate the ingenuity of a RV'r stuck along the road (or in the turn lane.) We were driving up the Coquihalla Highway (British Columbia) on the long steep section with our Class C and the engine started to loose power and speed. I was praying that we would get to one of the infrequent pull offs before it died. I limped into a pull off and it died as soon as we were totally off the road. I popped the hood and stood there looking at the engine expecting something to magically show me what the problem was.
    I started to wiggle wires in the hopes that something would start working. My wife yelled out that the heater wire started running. I jambed a thin piece of wood along the side of the offending connector, ran a jumper to activate my battery isolator and used the coach battery to jump start the RV.
    The battery would now charge off of the alternator and we finished our trip back to Wisconsin.
    That is called farmer engineering here in Wisconsin. I am also a farmer welder (meaning that my work may not be pretty but it will hold up to abuse.)
