FIRE_UP
Oct 26, 2017Explorer
Thunder Mountain wrote:
Just use the CoolTech harness. It is just dumb easy to install.
Thunder Mountain,
Well Sir, it may be "dumb easy" to install but, it does nothing to remedy this conflicting signal issue we've been discussing. I just corresponded at length, with a Cooltech technician and, he fully admits the problem exists and that many, many RVers are not aware of its happening. He stated what I already knew, that many RVers simply ignore it, even IF they know about it.
It really doesn't do much good to push the issue any further because many people simply don't care if their lights are working correctly or not. Many couples do a light check from the coach to the toad prior to heading out on the road. But, that's a static light check. But, things change drastically when the two vehicles are moving and, the toad has an auxiliary brake system involved.
Scott
Looking for advice before your next adventure? Look no further.25,197 PostsLatest Activity: May 19, 2026
