burber's avatar
burber
Jordan 2000-2020 users, need advice
Been away for quite a while. Thanks in advance for your time.
Having used my Jordan for over 10 years (and COMPLETELY satisfied with it), I'm starting to have an issue with it. I've just bought a new TT and the Jordan must not like it.
First off the TT connection at the TV is VERY tight, and I have to jiggle it a lot to get it all the way in.
That being said, when I picked my TT after warranty repairs, I stopped the first time and felt the TT pushing me. Looking at the Jordan, I had a green light (connections good) yet no digital read-out when brake pedal depressed OR manual button pushed. There was no braking at the TT with the manual pressing as well. After pressing the brake pedal numerous times, it started to work again.
Pulled to side of road and rechecked the connection between TV and TT; still got intermittent operation of the read-out. As I kept playing with the brake pedal and smacking the controller, it started to work....most of the time.
With my light being green all the time, doesn't that guarantee that my connections (between TV and TT) are good and the problem must be inside the controller itself?
I don't mind trying a repair on the Jordan (I'm a mechanic with good electrical skills), but I don't want to risk my family on a flaky brake controller!
And the really sad part is it appears I need to buy the $350 maxbrake system to at equal or better what I have gotten from my Jordan!!!!
    The Jordan depends on the position of the brake pedal and the Maxbrake uses the actual brake pressure to determine the output. I understand that Maxbrake may be going away because very few people understand the merits of driver controlled braking, so I would get one while you still can.
    Just because the trailer is new doesn't mean that the brakes are connected or adjusted properly.
Looking for advice before your next adventure? Look no further.25,149 PostsLatest Activity: Jul 21, 2025
