FastEagle wrote:
The Silver Fox Editions are like the Big Sky is to Montana. They are optional packages. If anything they, will add weight.
FE
Some time in 2013 there was a major upgrade in the frame/axles/capacities etc. With 6K axles this is one of the early models.
From OP sig line!
2013 Artic Fox 29-5T Silver Fox Ed.
Pin wt.(CAT Scale) 2660#
5th (Cat Scale) 12600#
If the 12600 is axle weight and it has 6K Al-Ko axles as he states, then he needs Arctic Fox to upgrade the axles. If 12600 is his gross weight then LT235/85R16E's will give him very good service if he chooses one of the steel ply carcass offerings.
Chris
