Bobbo
Dec 08, 2013Explorer III
I disinfect mine once a year, when I de-winterize.
I use 1/4 cup of bleach per 15 gallon capacity of the water tank. Put in bleach, then fill tank with water. Drive a little to mix the bleach and water, and also to splash the bleach/water onto the top of the tank.
Run the bleach/water solution through all the pipes, faucets, showers, tanks, everywhere water can possibly go. Run it till you can smell the bleach. Let it sit for 4 hours, then drain it all out, and rinse with clean fresh water.
That is all you ever need to do.
p.s. If you double the amount of bleach, you can cut the wait time down to 1 hour. I prefer the 4 hour method. I took enough microbiology to know some bugs just take time to kill.
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 18, 2026
