IH_Fan's avatar
IH_Fan
Keeping residential fridge doors closed during travel
Hi Folks,
We have a Prime Time Crusader 351 REQ 5th wheel that has the stainless steel side opening doors with the freezer on the bottom.
This is new to us and love the trailer, including the residential fridge option. With our first trip out this fall, we kept encountering issues with the doors opening while traveling. We used foam and wrapped bungee cords tight around the door handles to hold the doors closed.
It worked most times, but a couple times a can or jar would fall in such a way that the doors would open slightly and jam while travelling.
I'm almost at the point of hammering a 2x4 in the door handles to hold them closed (just kidding - for now!).
Has anyone else experienced this with your residential fridge, and if so, what fix did you use?
Thx!!
  • At an RV show last weekend I overheard a lady discussing that with a salesman. She said a friend had their residential style fridge door come open during travel and dump most everything in the floor. He was recommending straps something like these, the best I could tell from his description. Adhesive backed so there is no drilling required.
  • IH Fan
    Our solution is to not leave items that can force the door open in the frig. We purchased three plastic trays that fit side by side on the bottom shelf. One wide try holds all of our jars and condiments. Another wide one holds our bottled water. The narrow one is reserved for beer. On the shelf above we have a wide tray that hold two rows of coke cans which are on their side. Everything else goes in the door racks. Have not had the door open one time and everything stays organized. It also helps when unloading the frig when you get home. Works well and very little cost to solve the problem. Good luck
  • it should have a travel lock as a strap or a knob that screws in.The dealer did not show you this in your pdi?
Looking for advice before your next adventure? Look no further.25,151 PostsLatest Activity: Jul 27, 2025
