Mikesr's avatar
Mikesr
Keurig Storage (Freezing)
I know this topic was mentioned before but a solution to the problem was never really found.
We lost one Keurg to freezing over winter storage and another one that was semi froze during fall camping.
I've yet to call Keurig costumer service to see what they say. We like many others are hooked on theses machines. I would think they could invent a non toxic product under there label for winter storage.
Our problem is mostly during fall camping that we do in upstate PA when we leave the camper setup semi permanent from late August until mid to late November. We blow out the camper water lines and empty the water heater as the colder weather approaches and we use the camper on weekends. Just emptying the Keurig reservoir has not been enough to prevent damage. End of the season then we fully winterize the camper and remove the Keurig and store it at home.
I also have learned that all Keurig models are not the same. We like the ones with the reservoir tank and not the single cup model.
Thanks for any suggestions
  • I think ours is a B140. You turn the knob on the top to "drain", empty the reservoir and put it back on. The drain light/button will blink and you hold it down. The water will pump out into the reservoir, hold the button down until water stops.
Looking for advice before your next adventure? Look no further.25,116 PostsLatest Activity: Mar 11, 2025
