Hedgehog's avatar
Hedgehog
King size fitted sheets
Our new Montana fifthwheel has a king size bed. It is the full 72" X 80" but isn't very deep and it has rounded corners. We bought some king size sheets but they are all made for the real deep mattresses for homes. Can someone point me in the the direction of where I can buy fitted sheets for this mattress? If I can't find anything, I might trim down the plywood under the bed and put the queen mattress I had in our motor home.
  • We bought a very nice set of fitted sheets for our standard queen bed at home, from a discount store, at a steal of a price. Got the set home only to discover the sheets were too short! No return, of course. But when we tried them on the queen bed in the MH, they were a perfect fit! Bonus!!
  • rhagfo's avatar
    rhagfo
    Explorer III
    donn0128 wrote:
    You will probably lean real soon that that mattress is junk. Live with what you got u til such time as you figure that out and get a real good bed. Then your problems will be over. At least sleeping!
    LOL!!!
    HOW TRUE!
    First three trips in our Copper Canyon, DW had back aches and head aches! We made measured, and had true queen. We went to the mattress store and found one we liked with the correct firmness, has not been an issues since. We buy standard queen sheets, no issues, and we sleep like rocks.
  • Our King is 72x74 short. I bought jersey sheets from target and they work great. Get the cotton ploy blend and they stretch to a perfect fit. I bought queen size sheets.
  • They are actually suspenders. We've been using them for years. We have a 3" memory foam on top of the mattress and we still need the suspenders. I purchased a pair of men's suspenders at Wal Mart, spread them out in an X pattern under the mattress. Clip to the sheets and it keeps them tight.
  • You will probably lean real soon that that mattress is junk. Live with what you got u til such time as you figure that out and get a real good bed. Then your problems will be over. At least sleeping!
  • We used the sheet clips as mentioned above until we put a 2" memory foam topper on the bed, now they fit perfectly.
  • I know this doesn't address all your concerns, but some RV suppliers use oddballs. King is 76" x 80", Calif. King 72" x 84". I have read about other "King" (European) sizes. You could state your case to the seller and tell them you want a standard King or Calif. King. Use other RV's as an example.
    I've never been comfortable with the RV supplied mattresses...they are the first things to go...went to a Numbers air bed.
    Suspenders will work.
    I see from the Trackrig link there are RV Kings 72" x 80"...wish they would state the seam length.
  • old guy wrote:
    I saw once where a guy was using suspenders to hold his sheets in place
    Those are actual sheet clips and they work great.
  • I saw once where a guy was using suspenders to hold his sheets in place
  • Amazon has these for king size RV mattresses.
    Clicky
    And as a thought, I think MH mattresses are too thin so I put a 2" foam topper on them. That would add to your height to maybe make your new sheets fit better.
    Bill
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 18, 2026
