- Big_KatunaExplorer IIWhen that macerator jams you have to deal 1-2 gallons of raw sewage in your water bay. Happened to me TWICE.
With a tank rinser and a quality 3" hose, I never have to deal with a drop of raw sewage. - CampbellDaycruiExplorerDid you try asking your wife to hold her finger over the hole while you dumped? That would work.....
- cmcdarExplorer"at least with the macerator I don't have to clean "stuff" off my shoes that always happened to drip out of the hoses with the horrible stinky slinkies.
bumpy "
What? You must be dumping at home. Where and how are you dumping when you use your slinky? - BumpyroadExplorer
Lantley wrote:
Bumpyroad wrote:
MudChucker wrote:
Bumpyroad wrote:
throw away the stinky slinky and buy a sewer solution of macerator pump instead.
bumpy
sorry to derail the thread...
how long does it take you to "dump" with one of these ?
have no idea, I start it up and finish other chores.
I don't consider black tank dumping to be a race.
bumpy
It's good that you have chores to do while using your macerator because you will need something to do to pass the time away.
Maybe a good time to wax the entire RV and cut the lawn....and the neighbors lawn...:B
bumpy - LantleyNomad
Bumpyroad wrote:
MudChucker wrote:
bumpy
bumpy
Maybe a good time to wax the entire RV and cut the lawn....and the neighbors lawn...:B - minnowExplorer
youngone wrote:
getflexseal.com They have a tape. maybe it really works!
If it's anything like their other flexseal products, it would be cheaper to buy two replacement hoses. The tape probably won't even stick to itself. - BumpyroadExplorer
MudChucker wrote:
bumpy
bumpy - Big_KatunaExplorer IICut off the bad part.
A 10' extension is $16 at Walmart and a complete new 15' set up is $30.
A macerator is over $200 and is slow and can jam and requires maintenace every so often. And you still have a poop hose; its just a smaller diameter. - MudChuckerExplorer
bumpy
how long does it take you to "dump" with one of these ? - MudChuckerExplorerI used gorilla tape to fix a rip in my hose...its been so long ago since I did the repair I almost forgot about it.
Looking for advice before your next adventure? Look no further.25,106 PostsLatest Activity: Jan 28, 2025
