Dave_Pete's avatar
Dave_Pete
Explorer II
Jun 28, 2015
Lap Sealant vs Eternabond Tape
So here I am on the roof of our 2013 TT. That's because during a recent driving rain we got water on the carpet below a vent. Yep, two years old and the vent covers look like they are at least 10 years old and a small crack has appeared in the plastic near the crank metal support. All three vents covers getting replaced, as they all look and feel like you could stick a finger through them in about any spot.
But it was while on the roof checking this out that I ALSO see the factory applied lap sealant looking like it's getting old too. Natural expansion cracks appearing but enough questionable areas that I'm thinking I'll replace it all as well.
So here's the question. Would you clean it off and re-apply lap sealant or would you go further and apply Eternabond tape as a replacement for the lap sealant method?
  • swamprat 01 wrote:
    I use Dicor self leveling for horizontal and Dicor regular for vertical uses, I check my seams regularly and if needed re-caulk, I clean the edges with dawn soap and water and a small brush, I also wipe down the seam with alcohol the apply the caulk.
    I called Dicor and talked to a technical specialist. He strongly recommended cleaning with acetone after using any kind of soap product.
  • I decided my days of climbing up on the roof were going to be numbered, so a year or so ago I applied Eternabond...an am glad I did..:C
  • From what I see, Eternabond is the "permanent" way of fixing the problem, but with a few caveats:
    1: As stated above, it needs to be applied to a clean surface. Acetone is a must, and if there is -any- silicon based stuff, it need to be removed.
    2: To activate the microsealant, it takes heavy pressure with a metal roller. Don't try with a hand... it won't work, and you will just give yourself scrapes and blisters.
    3: It needs done in warm weather. If it is cold, grab a can of EternaPrime which helps with dirty/uncleanable surfaces, and allows work to -20 degrees.
    4: I'd caulk the edges of the EternaBond tape just for a better look. The downside of using EB is looks, so doing a neat job is important.
    5: Once EB tape is down, it is a PITA to remove, so it is likely there to stay.
    That was the other think they told me, it has to be rolled to activate the adhesive.
  • Here is the problem I have had with Eternabond tape. I used it a couple of times on the patio roof seems that leaked. After a few years... like 3 years it dries out in the HOT Florida sun and you have to clean it all off and re-do it. Then in about 3 years... again. I have not used the Lap seal so cannot comment on that.
Looking for advice before your next adventure? Look no further.25,101 PostsLatest Activity: Jan 14, 2025
