Desert_Captain's avatar
Desert_Captain
Explorer III
Oct 12, 2021
Latest project...parking pad for our cargo trailer
Our 6 x 10' cargo trailer has been an integral component for our many camping adventures for 3 years. I tow it behind our 24' Class C usually loaded with either our Rzr SXS or my Can Am Spyder. Destinations determine which toy to bring and we have nearly 25,000 miles towing the trailer.
For the last year I have squeezed in onto the north side of my driveway but it encroaches too much and is far from level. I finally made the run to Home Depot for 8 - 9" x 7" by 8' railroad ties that will form the pad for the trailer. The guys at HD loaded the ties 2 at a time {they weigh 150# a piece} using a forklift. I wrestled them out of my Honda Ridgeline ONE at a time.
Once they were stacked adjacent the build site the digging commenced. I hope to get the site dug down 4 to 6" and backfilled with small gravel so as to be level with the asphalt driveway. I'll drill the ties with a 3/8" bit and drive 2' 3/8" rebar to secure them in position. The last step will be to ramp gravel at each end.
Here are a couple of pics... definitely a work in progress:
Yep ,my little 570 RZR tows the {empty} 1200# trailer just fine.
Done for the day and at my age {70 next month} it is time for an Ibuprofen and a soak in the jacuzzi... I'll get back to it tomorrow {maybe?}
:B
  • Point taken but... you assume that I actually know where each tie is going. :h
    LMAO... but seriously I plan on creating g a 16' X 4' box with a couple of stringers dug down flush with the top of the asphalt driveway. This I will back fill with small course gravel with a couple of inches of the larger concrete gravel on top.
    I utilized this formula with good results when I expanded the concrete driveway to a create a larger footprint/pad for the Class C. Obviously nothing is set in stone {sorry, pun intended}. I hope to end up with a smooth enough approach to the pad that I will be able to move the {empty} trailer off of the driveway and onto its pad using just a hand dolly.
    Film at eleven!
    :B
  • One mistake I can see already; Should of done the digging before you picked up the ties. Then you could park close to where each tie belongs before unloading.
    I did not get this fat working harder than I needed too.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Dec 14, 2014
