dodge_guy
May 01, 2016Explorer II
That short distance is not much. It will not cause any adverse problems. True the axles are arc'd for positive camber, but it would take quite a bit of lift to change that, I'm talking several inches. If you just use the lower hole on the center hanger everything will still be fine.
BTW, it would be very easy to bend that bent hanger back out!
Looking for advice before your next adventure? Look no further.25,112 PostsLatest Activity: Feb 21, 2025
