wmowat's avatar
wmowat
Leak while away
Hi Folks,
I'm new to the forums but have run into a bit of a problem. I drove my travel trailer from Canada to Orlando for the holidays. All was going well until we noticed some water pooling into the bathroom this morning. I traced it back to a connection at the water tank I believe. I'm running off of city water and it seems to be coming directly from the joint somewhere. When I was inspecting it I noticed the plastic connections were a bit loose and tightened it but that didn't seem to help at all. It could also be coming from above where the seal is. I attached a pic of the area the leak is coming from (cold water joint). Any advice? I'm very new to rving and far from home so I'm not sure if I should just shut the water off until I get home. I have a pressure regulator on my city water connection but and wondering if the pressure is still too high. No leak from the hot water tank, just cold.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
