Bob_Vaughn's avatar
Bob_Vaughn
LED bulbs 1144
I went to camping world intent on replacing 20 bulbs with LED's until I seen they were 36 bucks each so that idea went right out the window....
  • tenbear wrote:
    Depends on your fixtures. I have read of people using wire ties to to attach their panels. Also some have used silicone glue. I have had success by sanding the plastic fixture where the sticky tape attaches.
    The issue I have with the tape is that it gets soft from the heat.
    I had not thought of silicon. The automotive high temp would be perfect.
    Thank you!
  • Depends on your fixtures. I have read of people using wire ties to to attach their panels. Also some have used silicone glue. I have had success by sanding the plastic fixture where the sticky tape attaches.
  • Ivylog wrote:
    Instead of searching for 1144 use BA15D. I would try this one for $3.25. Another option is a panel like this with a BA15D adapter/plug.
    I just bought 20 of those to retrofit both of my 5ers. I had heard some complaints about heat using this style of led. I found that they run cooler than the 1144's they replace.
    They do run hot enough that I do not have faith in the double sided mounting tape they come with and am looking for mounting alternatives.
  • Ivylog's avatar
    Ivylog
    Explorer III
  • I suggest you look on eBay. Do a search on "led ba15d". You probably want 24 or more 5050 leds or the equivalent. The 1144 seems to be a pretty bright bulb.
    Buy a couple to see if they are what you want before you buy a whole bunch.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 16, 2026
