wa8yxm
Apr 15, 2014Explorer III
2oldman wrote:
I don't know the wattage of 1141s.
I believe they are 18 or 19 watts without looking it up.. a 1156 is around 26 watts. (looked it up some time back so I am typing from memory)
if you want the exact figure Google: 1146 Lamp Specifications
That will bring up links to it.
NOTE: this applies to any standard lamp.
The LED equivalent is something like 4 or 5 watts if I recall correctly. 20 watts times 24 hours is 448 watt hours, figure one 1/2 KWH per day, so if you are paying 30 cents a KWH and using the lamps 1/2 of the day, you'd need about half a year to save 10 bucks. The fact you are running through the converter is not a factor.. watts are watts.
NOTE: all numbers are "If I recall correctly" if I'm wrong.. Adjust the math.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
