OldRadios
Apr 15, 2014Explorer
One other savings you might be able to figure in is the heat incandescent give off. If you have to run the air, LEDs won't add to the heat problem like incandescents. Good luck trying to figure out that savings though.
When I tested both 1141 incandescents and LEDs on my bench the 1141 incandescent was 20 watts and the replacement 1141 LED was 2.7 watts. (at 13.2 Volts DC)
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
