Paul1944's avatar
Paul1944
LED Light Fixtures
I'm considering changing SOME of the light fixtures in my MH to the LED type. I'm looking for recommendations from anybody who has any experience with this type of fixture. A couple questions off the top of my head; are the LED fixtures worth the cost?, are they that much better than the 12v bulb type?, how difficult are the fixtures to change? I have a 2000 Fleetwood Bounder Motorhome. Thanks in advance.
  • We changed some of ours to LED, but just changed the bulbs. Got LEDs from Amazon. It was easy to do, and sure helps conserve battery power when dry camping.
  • First question... are the worth the cost? Well, I don't know. The main advantage to LED over incandescent and/or florescent is the electrical usage. LEDs use MUCH less. However, since most of us don't pay for our electrical hookup by the amount of electricity we use, rather than by a flat fee.... I can't really say they are worth the cost. However...if you boondock a lot, then there would be much less drain on the batteries and in this case, probably would be worth the cost.
    Second question...how difficult are they to change. Well, those that replace the incandescents are exactly the same type of connection...so really no more difficult to change out. Florescents, are totally different and do require some cutting and splicing in the fixture.
    Me... I'm waiting until the cost of the LEDs come down....a whole bunch. I think they are just too expensive right now.
    My two cents anyway..
    Ron
  • Ivylog's avatar
    Ivylog
    Explorer III
    Normally all you do is replace the bulb. What # are your bulbs? The LEDs use 1/10th the power and very little heat. Plenty of posts on this subject, but helps to know which bulb. Assuming a 1156 they are not that expensive.
Looking for advice before your next adventure? Look no further.25,164 PostsLatest Activity: Sep 17, 2025
