Buster52's avatar
Buster52
Lift points on a 1989 GM P30
Where are the lift points on the chassis of a 1989 GM P30? I need to replace the air springs and noticed that on my Southwind 30E and notice that in the back that most places you would place a bottle jack is where the gas tank is. Leaving little room to work.
Thank
Buster
  • Buster52 wrote:
    Yes it does set between the rails, right against the rails. No room to more right or left. And if it slipped you hit the gas tank.
    Don't slip :) Once it's sitting on jackstands it's not going anywhere.
    Mine's the same way. My gas tank is wedged in there so tight I couldn't get it out even after removing the straps. I had to cut a hole in the floor to replace the lines instead.
  • Yes it does set between the rails, right against the rails. No room to more right or left. And if it slipped you hit the gas tank.
  • I would think anywhere along the frame rail. Doesn't the gas tank sit in between the frame rails?
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 15, 2026
