Harvey51 wrote:
Higher quality LED lights have built in voltage regulators to prevent damage to the LEDs - but wouldn't the regulator chip dissipate the power reduction as heat?
I don't know a lot about the regulators used in LED lights but I believe they use switching circuits that turn the power to the LED off and on very rapidly. That is what causes radio interference from some regulator LED lights. The switching circuits cause much less heat than using resistive limiting of current.
I switched all my 1141 lights to non regulated LEDs some years ago and while a few have had some LEDs go out, they are still giving off lots of light. I think the problem I had was that when I attached the panels to the light fixture I bent the panels and damaged the connections to the LEDs. The cob style lights are still working perfectly.
