ktmrfs
May 20, 2017Explorer III
2oldman wrote:
The OP wants a simple version. The switching power supplies are for you technicians here.
simple versions and shore power are a BAD combination. converter will go to 14.6V occasonally and lead to thermal runaway on the lights with just a dropping resistor.
LED are a CONSTANT current device, NOT constant voltage. driven from a voltage source as they heat up, junction voltage goes down, current goes up more, leakage current goes up, LED gets hotter, get the picture.
for a trailer if you are expecting them to last any length of time you want ones that specify a wide operating voltage range, say 9-20V or more. these drive the LED with a constant current.
Otherwise they can actually get hot enough to melt the solder on the circuit board.
Anymore the goods ones are reasonably priced.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
