the basic rule of thumb is that the max weight you can safely tow is the LESSER of the following:
- the difference between the GCWR and GVWR. both are published numbers by the RV mfg. if you can't find the GVWR you csn get a good approximation by adding the GAWR (gross axle weight ratings).
- the weight rating of the hitch
- the weight rating of the towbar.
is the 11,030 the GVWR of the MH? assuming it is then the maximum weight you can tow,is 4,220-lbs. and that assumes that your MH weighs no more than 11,030-lbs when fully loaded for travel. fully loaded includes everything in the MH...food, fuel, water, LP, clothes, supplies, food, people, etc. it also assumes that neither axle is overloaded...each axle has it's own weight ratings. a 5000-lb towbar would be fine and when flat towing there is negligible tongue weight (no significant downward pressure on the hitch). but the 11,030 is a weird figure. GVWR's are usually even numbers like 18,000, 24,000 or even 19,500-lbs.
